In the Rhino WIP, you will find a number of improvements related to corner surfaces created with the FilletEdge and BlendEdge commands. They can create Setback Corners. These corners usually offer better continuity and improved aesthetics.
- Setback surfaces are constructed from multi-blends.
- Multi-blend quality has improved.
- Setback now also works with concave corners.
- Multi-blends are now applied in cases where Rhino would previously create gaps.
Setback Corners
Setback corners create a softer transition where the different edges meet. In the Rhino WIP, setback corners are now also possible in FilletEdge
Setback corners are implemented with multi-blends, a number of surfaces that meet at a common central point and close a hole with multiple edges:
left: setback with 6 edges and 6 surfaces in the multi-blend; right: non-setback corner
Improved setback quality
From your feedback and from internal testing, it turned out that the existing implementation of setback corners - which is used for BlendEdge in v8 - was giving problems in a number of cases. Two examples of these problems are shown below, for acute corners and for concave edges.
Acute setback corners
On a model with sharp corners, the setbacks are wobbly, here indicated by Zebra analysis:
Rhino 8 setback
One of the reasons for the wobbliness is the surfaces that make up the corners stray outside the original shape of the model:
This wobbliness has been addressed and the Zebra light lines look much better in Rhino WIP:
Rhino 9 setback
No more bloated corners
Concave Setback Corners
In Rhino 8, concave corners - indicated below with arrows - were not supported. In Rhino WIP, this support has been added.
What’s more, continuity - as analyzed with GlobalEdgeContinuity below - is improved in many cases:
4-edge and 6-edge corners
With the re-written multi-blends, application of multi-blends is possible in more cases. Two are highlighted below, for setback and non-setback 4- and 6-edge corners.
Non-setback 4-edge corner
Setback 4-edge corner
Non-setback 6-edge corner
Download the example file… (2.1 MB)
We expect that this kind of corner with multi-blends will find its way to more cases in upcoming WIP versions.
Stay tuned for more as we continue to develop Rhino!
Download the Rhino WIP…
