Chris40
(Chris)
December 13, 2024, 5:35am
1
if I do all the facade in rhino and export in revit using RIR, how to deal with those 2d drawing such as open door in plan drawing, using derail line to fake a door open line?
Japhy
(Japhy)
December 13, 2024, 3:16pm
2
Hi Chris,
2D elements are view dependent and depending on your workflow may be better suited as a family or detail component.
If you post a small example of what you are trying to do we get a better understanding of your workflow.
4. Isolating the issue and posting files
Revit projects are rarely small & the issues are rarely simple. Its understandable that support files aren’t always readily uploadable, for size or for privacy concerns.
That said, here are some recommendations:
Isolating the question to a new Revit file with the Revit Version in the File Name, then purge the Revit file several times to reduce size.
List your GH plugins needed to review the question, if possible remove all gh plugin components no…
