I am looking for some advice on how to transfer a 2D detail drawing from Rhino to Revit. I have tried exporting the drawing as a DWG file and importing it into Revit, but the result is not satisfactory. The lines are distorted and the dimensions are inaccurate. Is there a better way to do this? Has anyone successfully converted a 2D detail drawing from Rhino to Revit? I would appreciate any tips or suggestions. Thank you.
Hi Arqueiro, Please see our Drafting Components.
Can you post a sample of your details and a description of your ideal workflow? Thanks.
I wonder if anyone ever did something similar.
Typically people import DWG into a Revit Template file specifically setup to cleanup the imports. Then bring them into the project sans the potential messy imported styles.
What is your ideal workflow?
