I’ve updated my licence key, uninstalled Rhino 6, opened Rhino 8 in safe mode and disabled all plugins, but my Rhino 8 still freezes just when it looks like it’s loaded. I’ve previously had the trial version running fine. Here’s my System info:
OS Name
Microsoft Windows 10 Home
Version
10.0.19045 Build 19045
Other OS Description
Not Available
OS Manufacturer
Microsoft Corporation
System Name
MOIRAPATIENCE-M
System Manufacturer
ASUSTeK COMPUTER INC.
System Model
GL502VMK
System Type
x64-based PC
System SKU
Processor
Intel(R) Core™ i5-7300HQ CPU @ 2.50GHz, 2496 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date
American Megatrends Inc. GL502VMK.308, 03/05/2019
SMBIOS Version
3.0
Embedded Controller Version
255.255
BIOS Mode
UEFI
BaseBoard Manufacturer
BaseBoard Product
GL502VMK
BaseBoard Version
1.0
Platform Role
Mobile
Secure Boot State
On
PCR7 Configuration
Elevation Required to View
Windows Directory
C:\WINDOWS
System Directory
C:\WINDOWS\system32
Boot Device
\Device\HarddiskVolume2
Locale
United Kingdom
Hardware Abstraction Layer
Version = 10.0.19041.3636
Time Zone
GMT Standard Time
Installed Physical Memory (RAM)
8.00 GB
Total Physical Memory
7.96 GB
Available Physical Memory
2.42 GB
Total Virtual Memory
23.0 GB
Available Virtual Memory
14.0 GB
Page File Space
15.0 GB
Page File
D:\pagefile.sys
Kernel DMA Protection
Off
Virtualisation-based security
Not enabled
Device Encryption Support
Hyper-V - VM Monitor Mode Extensions
Yes
Hyper-V - Second Level Address Translation Extensions
Yes
Hyper-V - Virtualisation Enabled in Firmware
Yes
Hyper-V - Data Execution Protection
Yes
Japhy
(Japhy)
March 4, 2024, 1:46pm
2
Hi Meg, Can you reinstall 6 real quick & run systemInfo?
What display adaptors are you running? (systeminfo will provide more details)
Lets try creating a shortcut with the netfx flag in the shortcut to eliminate an old Rhino 6 plugin interfering. If unsuccessful remove the /netfx flag after testing.
To start Rhino in .NET Framework once:
Create a new shortcut for Rhino in Windows
Edit the shortcut
Add command line argument /netfx
Adapter Description NVIDIA GeForce GTX 1060
I’ve uninstalledRhino 8 and installed Rhino 6 again and now it’s also playing up. I tried the /netfx addition to a shortcut but Windows won’t let me apply it
update: I ran “C:\Program Files\Rhino 6\System\Rhino.exe”/netfx through the run command and it tried to open but froze again
Japhy
(Japhy)
March 4, 2024, 2:11pm
5
That flag is only for Rhino 8
Lets repair your Microsoft Redistributables
the x64 is what you want
done that. Rhino 6 still froze. Have uninstalled 6 and reinstalled 8 (fresh download) and tried the /netfx shortcut but had the same problem. Rhino 8 still freezing on startup.
Japhy
(Japhy)
March 4, 2024, 2:35pm
7
Are there any errors shown?
Something is wrong with your Windows, is it fully up do date? Do have a aggressive virus protection software installed?
I would focus on the Rhino 6 install first, less variables.
is this a laptop with a hybrid graphics system ?
here is a microsoft .net repair tool
https://www.microsoft.com/en-us/download/details.aspx?id=30135
I’m back with Rhino 6, have updated my graphics card driver, run a virus scan (all clear), and run the .net repair tool. I didn’t think this was a hybrid but have been through the guide and set Rhino to default to the highest performance option (though both options say the same GeForce card). Rhino 6 still freezes when trying to open a file I was successfully working on this morning before trying to upgrade to 8.
Japhy
(Japhy)
March 4, 2024, 3:15pm
9
Thanks, please run SystemInfo in the Rhino command line and paste your results.
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo. In use by: Meg Walker ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 8Gb)
Machine name: MOIRAPATIENCE-M
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: (null)
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
Japhy
(Japhy)
March 4, 2024, 3:17pm
11
This via safemode? Rhino 6 won’t open normally?
no it freezes before opening
this is what I get to but it’s not responding
Japhy
(Japhy)
March 4, 2024, 3:24pm
15
Meg Walker:
GeForce GTX 1060
The video card is having issues. A clean install of the NVidia drivers is recommended first, then try older drivers (with clean installs each time)
To clean install a nvidia driver choose Custom install and enable the Clean Install checkbox.
hang on, I just tried removing my second monitor and it’s opened ok! could that be the problem somehow?
I’m going to do this anyway
Japhy
(Japhy)
March 4, 2024, 3:29pm
18
Yup! getting closer, could be something physical about the port or how the driver is reading the monitor.
