Rhino 8 the "export selected" to a .dxf file fails
the command “export selected” in Rhino 8 to a dxf-file seems to be working fine, but the dxf files has nill content? -modell1.dxf 0 KB-
It dosn’t matter which dxf format I choose.
In Rhino 7 the same file works pretty good as always!
Is it a bug?
Christoph
Is this with any file, any kind of object(s)?
it’s with any file (complex,simple etc.).
it depends on wich export sheme I’m using.
I haven’t tried them all but the export sheme “2018 lines.dxf” doesnt’t work
the other shemes work as long I don’t I change the sheme manually
e.g “Export surfaces as:” from -solids- to -meshes- the output fails
