Hi everyone, it’s been a while since I’ve used Rhino.
I need to export a simple wireframe drawing to dxf to do structural analysis.
If I try to do this though it tells me “Error creating file”. I’ve never had this problem before.
Is this due to some update by any chance?
Can anyone help me?
I attach an example file. prova x esportazione.3dm (152.4 KB)
Where is the SystemInfo command? i’m searching but i didnt find it.
Anyway i tried to export for example in .igs and it create a file. Anyway i need a dxf or a dwg
Hello - I assume this must be already the case if you are seeing the export dialog, but can you please check Options > Plug-ins page and make sure the export plug-ins for ACAD are enabled?
I have searched for the SystemInfo command, also in the Diagnostics group, but it is not present.
I have version 5, maybe it wasn’t there.
What could we do?
-Ascanio
