Hi I can’t export to dxf file, it is a very simple file for the lazer cutting machine. It has always worked for me before but now I get this dialog box pop up and can’t find any solutions online. Anyone know how to fix this?
Hello- detail objects - the selected object in your screen shot - are not supported in the export to dxf. If you want to export the contents of that layout use SaveAs to dxf - any luck?
Im using Rhino 7 on Mac and when I select the objects and use the SaveAs command it can only save as a .3dm file…
Hello - sorry - use ExportAll on Mac.
