Rhino 8, dxf export parameters unavailable
I’m trying to export my drawing in dxf format with Rhino 8, but I can’t change the dxf parameters?
See the screenshot.
Best,
Benoît
Hi Benoît -
When you create a simple rectangle in a new Rhino document and export that, does the error still pop up?
Hi Wim,
Yes I confirm, I have the same error.
I can’t access the window containing the presets (Options). The problem appears when I ask for it.
Benoit
Is there finally any solution to this problem?
Rhino 8 is out now, but I still cannot access the AcadSchemes.
Can you run the SystemInfo command and paste the results here?
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09002, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Éducation, version 2023-10-31
License details: Cloud Zoo
Apple macOS Version 14.1.1 (assemblage 23B81) (Physical RAM: 64Gb)
Mac Model Identifier: MacBookPro18,2
Language: fr-CH (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (2056 x 1329 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23304.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23304.9002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23304.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23304.9002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23304.9002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23304.9002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rendu de Rhino” 8.0.23304.9002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23304.9002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23304.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.0.23304.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23304.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23304.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23304.9002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23304.9002
This also happened on another computer:
Apple macOS Version 14.1.1 (assemblage 23B81) (Physical RAM: 16Gb)
Mac Model Identifier: iMac19,1
.NET 7.0.0
Metal GPU Family Apple 0
Graphics processors
Radeon Pro 575X (4 GB)
iMac (2560 x 1440)
USB devices
Logitech: USB Receiver
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
None
None
Third party plugins
I couldn’t reproduce the error here. I checked to see if I could, by turning to French. I notice on both machines you are running 14.1.1, I am running 14.0
I will try updating and see if that makes a difference.
I managed to reproduce this in the 8.0 release. This should be fixed if you install the current SRC (https://www.rhino3d.com/download/rhino/8/latest/rc/)
Perfect, it works. That’s nice, thanks!
