Rhino 8 - Stuttering Viewport Problem
Hello!
Recently I’ve noticed that my viewport stutters constantly when panning/rotating around my models in Rhino 8. All my models are quite simple, file sizes are very low (<1MB), my drivers are up to date, and my computer isn’t stressed at all. Is there a reason my viewport should be stuttering like this?
Whether related or not, I’ve also noticed that Rhino is crashing more and more often, and I frequently get a “Rendering failed: Switching to Wireframe mode” error after completing curves or polysurfaces in Shaded view. I’d assume this is from maxing out my GPU or RAM, but I’ve done far more complicated tasks without a hitch. These models are just a handful of basic curves and polysurfaces.
Does anyone have a solution to this?
Thank you!
240225_Rhino 8 Stuttering Viewport
What kind of GPU do you have?
Try to upgrade your drivers.
And post your system info if you can.
(Just type SystemInfo and paste the result here)
I’m on an NVIDIA RTX 3050 with 6GB, installed in a minimalist laptop I bought last month for work while traveling. It’s not the beefiest machine, but it’s been smooth and fast in Revit and Blender (and Rhino, minus the above issues ^). Drivers seem to be all up to date:
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Commercial, build 2024-02-13
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [23% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 2-22-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 6GB Laptop GPU (NVidia) Memory: 6GB, Driver date: 4-25-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.97
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-25-2023
Driver Version: 31.0.15.2897
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24044.15001
Thanks!
Everything seems fine, but did you experience the stutter while on battery?
I would check the power settings to make sure Rhino get’s full power when needed.
I just checked on my home computer and drew a circle and polar arrayed it 100 times, then those 100 times and those 100 times, resulting in 1.000.000 circles and Rhino handled this well (Not silkey smooth, but smoother than what you showed) on a RTX2070 and an i7 10700 on a ultrawide monitor. (The 2070 has about 40% more raw power than the 3050, so that is taken into comparison)
So your hardware should be more than up for the task. Question now is just why it doesn’t perform. Maybe it switches to the Intel Iris to save power.
According to your system info your Nvidia driver is nearly a year old.
I recall a recent post here a week or so ago where display performance with a driver only 2-3 months old was troublesome and cured with a driver update.
Your Intel video driver could probably use an update as well. It is a year old.
Great - I manually installed new drivers from NVIDIA’s website and the stutter seems to be gone.
Shouldn’t have trusted the Windows auto-search for new drivers telling me they were up to date I guess. I’ll do the same for the Intel drivers and keep better track of them from now on.
Thank you both for the help!
As an update to this thread, just for consistency -
Installing new graphics drivers did solve the problem temporarily, though the viewport stutter came back. I played around with the power settings on my laptop and found that my files only stutter when running on battery power (even with Windows’ power settings set to prioritize high performance).
When I plug my laptop in, however, the stutter goes away completely. I need to run 6 or 7 apps at the same time for these projects so it’s possible Rhino isn’t getting a big enough share of power when running on battery; keeping my laptop plugged in is a fine enough solution for me.
Hi All,
I am experiencing the same issues as Jack. However, in my situation, the stuttering is much more severe. After installing new graphics drivers (for both integrated graphics and rtx 3050ti laptop card) the issues remained.
Curious if someone can assist in solving this! Pasting my SystemInfo below.
Many thanks in advance!
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 5-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.85
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 5-13-2024
Driver Version: 32.0.15.5585
Total Video Memory: 4 GB
C:\Users\bartr\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23345.954
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
Hey Bart -
Is this behavior file-specific?
Does it change when you disable all 3rd party plug-ins and restart Rhino?
What happens when you only use the laptop’s screen and disconnect all other monitors?
Hi Wim,
Thanks for your reply. To answer your questions:
  • Not file-specific, behavior even occurs with standard template files;
  • If all 3rd party plug-ins are removes (clean install of rhino) the issue remains;
  • behavior occurs without connection of external monitors.
Please note that I am running Rhino 7. See SystemInfo log. I am sharing this again here:
Computer platform: LAPTOP - Unplugged [79% battery remaining] ~96 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Render version: 4.6
Also, when panning geometry gets transformed in it’s “bounding box”, see image below.
Hey Bart -
Thanks for that information.
Could you post a screenshot of the entire Rhino interface?
I take it that this only happens in a more complex scene, and not, e.g., in a scene with just a simple box? If that also happens in relatively simple scenes, I’d check that the GPU isn’t getting very hot because of blocked vents. Also, that behavior can be modified by changing the fps setting on the Rhino Options -> View page under “Dynamic redraw” - and can be forced to be on per display mode on the Objects page, under “Dynamic display”. So, I’d check to see if all those are set at the defaults.
Hey,
I have the same problem with my Rhino 8, it stutters while panning, zooming or orbiting. I recently switched from PC to laptop and it only stutters while on the laptop, the laptop is always on plugged in, but it still stutters. Can someone help with this issue?
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Commercial, build 2025-04-10
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Primary display: Intel(R) Arc™ Graphics (Intel) Memory: 2GB, Driver date: 7-24-2024 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
  • Windows Main Display attached to adapter port #1
  • Secondary monitor attached to adapter port #2
    Primary OpenGL: NVIDIA RTX 3500 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 10-29-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.80
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 10-29-2025
Driver Version: 32.0.15.8180
Total Video Memory: 12282 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25100.11001
Hi Akram -
Is this with a specific model or does that also happen when you reboot, launch Rhino, and only create a simple box?
Does it make any difference if you disconnect external screens?
@wim
I rebooted rhino drew a simple box, and still the same problem with stuttering. and I tried as well to disconnect the external screens and still stutters
