I am currently using Rhino 8 SR34 (8.34.26223.11001) on Windows 11.
Every time I use the Make2D command, Rhino crashes and closes completely after a few seconds of processing.
This issue occurs repeatedly and is not limited to large or complex models. I am unable to use Make2D at all.
Another computer with nearly identical hardware specifications (64GB RAM and NVIDIA RTX 4070 Ti SUPER 16GB) runs Make2D without any issues using Rhino 8 SR29 (8.29.26063.11001).
I suspect this may be related to the Rhino version or my installation environment.
I have included my full SystemInfo below for your reference.
Could you please help me identify the cause of this issue? I would also appreciate it if you could provide the Windows installer for Rhino 8 SR29, so I can test whether downgrading resolves the problem.
Try disabling all of your 3rd party plug-in. To do so, pick Tools > Options > Plug-ins and filter on “Plug-ins that do not ship with Rhino.” Then uncheck (disable) all the items. Close the dialog and restart Rhino and try again.
