After updating from Rhino 8 SR 9 or 10 (August 2024) to SR27 my sessions developed issues with incomplete lines following the Make 2D command. I have tried many variations of settings, including clean re-installs, however the issue persists even with the most up-to-date release.
I had initially upgraded to ensure plug-in complatibility, however am considering re-installing an older version to see if the issue resolves.
I am unable to find archived releases to troubleshoot - it appears that they are only available via McNeel admins.
Hi Japhy, thank you for the fast reply! I’ve attached a small R8 file that exhibits the behavior on my machine - there are layers named with the resulting output from different views, with active clipping planes.
