Rhino crashes consistently when using Make2D
I am an architecture student using Rhino for my building modeling projects.
I am currently experiencing a critical issue where Rhino consistently crashes and closes immediately whenever I try to run the Make2D command on my models.
Interestingly, when my classmates open and run Make2D on the exact same project file on their computers, it works completely fine without any issues. On my computer, the command works without problem for very simple geometry, but it consistently crashes whenever the model contains a moderate to large number of polysurfaces.
Given that my hardware specifications are quite high, I suspect this might be a software conflict, driver issue, or a specific setting rather than a lack of system resources. Here are my system specifications captured from the Windows Task Manager:
  • CPU: Intel(R) Core™ i9-14900K (24 Cores, 32 Logical Processors)
  • RAM: 128 GB DDR4 (4000 MT/s)
  • GPU 0 (Integrated): Intel(R) UHD Graphics 770
  • GPU 1 (Dedicated): NVIDIA GeForce RTX 4090 (24.0 GB Dedicated VRAM, Driver version: 32.0.15.6109 / Date: 2024-09-05)
  • OS: Windows 11
Could you please advise on what might be causing this issue and how I can resolve it?
Hi 명수아
Please run SystemInfo in your rhino command line and post the results.
Are you getting a rhino crash report? I do not see any with your account.
Yes, the crash report window does pop up. I sent a report once when it crashed, but if it’s not showing up on your end, should I submit another one? Here is my SystemInfo:
Hi 명수아 -
The current version for Rhino 8 is 8.32. Please update your installation.
your graphics driver is 2 years old… it’s worth upgrading that to the current version as well.
Important, do a clean install.
when you install it will ask you for a basic or advanced install, do the advanced and look for the clean install checkbox. click that and proceed with the install.
