Hi, I installed Rhino 8 but is unusable since it crashes when executing any modeling command ie a simple box or a curve.
This doesn’t happen when launching Rhino in Safe Mode.
Can you run Rhino in normal mode and once it starts, before executing any other command, run SystemInfo and copy/paste the results here?
Running ok in safe mode points towards video card environment or a plugin issue.
Hi @Dario_Belaga,
I don’t see that you’ve submitted any crash reports. When Rhino crashes, are you seeing the “Rhino has crashed” dialog?
Thanks,
– Dale
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15431, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Commercial, build 2024-05-17
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 12GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) HD Graphics 4600 (Intel) Memory: 1GB, Driver date: 11-4-2020 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.5171
> Integrated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.3
Shading Language: 4.30 - Build 20.19.15.5171
Driver Date: 11-4-2020
Driver Version: 20.19.15.5171
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24138.15431
Unfortunately your laptop is simply far too weak to run Rhino 8….
Hi @Dario_Belaga,
Your system doesn’t meet the minimum requirements for video.
This is quite old. You’ll will want to look into updating this.
– Dale
Thanks everyone, I downgraded to rhino 7 and its working perfectly!!
