Rhino 8 | Section Drawings | List of bugs
I’ve come across a few bugs in Rhino 8 (RH8 SR9) related to the section tool. I’ve compiled a list of them in one post to keep the forum organized.
Thank you for addressing these. Perhaps there’s a setting I’m overlooking.
  1. Section Drawings -
    1. Geometry below and above not displaying correctly.
    2. Not cutting through blocks correctly
    3. Editing section drawings after placement command makes drawing disappear - Redo
    4. Hatches often only visible in wireframe mode
  2. Section drawings | Placement point -
    1. What is the exact position of the placement point relative to geometry?
    2. Odd placement point location
  3. Relocating section drawing - unlocked layers revert back to previous position after update
Section
Section Drawing
Placement point
@rajaa Please, any idea to handled / fix it? Thank you!!
Hi, sorry it took a while to get back to you. I was on vacation and missed your message.
Can you please share an example that I can test with. Also, please try the latest service release and let me know if that works better for you.
To answer your questions:
Not sure I understand. Can you share a small 3dm example file?
It should work. Can you please share a small 3dm example file?
How are you exactly editing?
Can you please give a 3dm example file?
The placement point is the center of the section.
When you add or modify the geometry in your model, the placement point is saved in the section to help align updated section exactly on top of the old ones.
You should use use EditClippingDrawings to change placement of a section. Unlocking and replacing manually does not change the placement point saved in the section
Hi Raja,
Thank you.
Please see the attached file. The horizontal section facing downward (floor below) is simultaneously displaying the floor above section, which it should not. For example, walls in the upper floor.
Unfortunately, it doesn’t. I have placed the blocks within revision clouds.
Using commands to edit the clipping drawing and then the placement point, if the command is executed and you press Ctrl+Z, the drawing disappears entirely. You need then create completely new section drawing.
Please find attached
The issue arises when I reference a DWG site drawing of a city section. The reference point is located at a great distance. Even though I disable the XREFs layers, the point persists, including the entire DWG.
I understand, but I’m unable to precisely align the floor plans and sections because the placement point varies in different locations.
0019_M_240620_FORUM EXAMPLE.3dm (11.8 MB)
Just following up on some of the items raised in this post.
Is there a currently useable workflow for aligning a series of generated drawings? Ie. groud/first floor plans - is there a straightforward way of placing these in the model space such that they are aligned in the X direction?
If placement point related to the origin then I could see this being fairly straightforward, but if it’s the centre of the clipped drawing and you can’t just move a drawing, only re-place it and you can’t see the drawing when you’re placing it, it becomes quite tricky.
RH-89030 is fixed in Rhino WIP
