Maybe it’s a possible BUG in section tools. Hard to explain. Please watch the video. Basically I generate a plan of a building, using “section tools”, create drawing. Then, when generating another layout page, the 2D plant drawing disappears. :-). This week I have 40 students who must generate documentation via section tools, and things are not going well. I hope someone can help me. Thanks.
Hi Alfonso, welcome and thank you for reporting this. I have created an issue https://mcneel.myjetbrains.com/youtrack/issue/RH-82197
Can you please let us know which version of Rhino you are using, and post the details from the SystemInfo command.
Dear Menno,
Tks
I am using Rhino 8Sr8
Rhino 8 SR8 2024-5-21 (Rhino 8, 8.8.24142.13001, Git hash:master @ cf2a36827c139ab301c2560ae9153ea7a926bdec)
License type: Not For Resale Lab, build 2024-05-21
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 15GB)
.NET Framework 4.8.9241.0
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-7-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.44
Integrated accelerated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-7-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.44
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 1-19-2023 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
Secondary monitor is laptop’s integrated screen or built-in port
Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-7-2024
Driver Version: 31.0.15.5244
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Users\Affonso\AppData\Local\Programs\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24103.837
C:\Program Files\Rhino 8\Plug-ins\RhinoCAM 2024 for R8\RhinoArt1FileExporter For Rhino8.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Rhino 8\Plug-ins\RhinoCAM 2024 for R8\RhinoCAM 2024 For Rhino8.0.rhp “RhinoCAM 2024 - The cutting edge CAM plug-in for Rhino 8.0 from MecSoft Corporation”
C:\Users\Affonso\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\2.2.0.180\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24142.13001
C:\Users\Affonso\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24142.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24142.13001
tks
Hi Affonso -
Thanks for the SystemInfo data.
I’ve tried to reproduce the issue that is shown but am unable to do so here. Could you post a (simpified) 3dm file that we can use to try to reproduce this here?
RH-82197 is fixed in Rhino 8 Service Release 9 Release Candidate.
section tools affonso orciuoli.3dm (2.9 MB)Dears, here the file
Hi Affonso -
The issue that was reported in this thread was fixed in Rhino 8 SR 9 and had to do with layouts. The file you posted now was saved in Rhino 8 SR 17 and contains no layout at all.
If you want to report a different issue, please start a new thread.
Dear Win,
check the file attached. See the plan result. It´s not correct. There are really strange lines. Tks, best
Hi Affonso -
The only problem I see here is that the balcony object only gets partially drawn by the ClippingDrawings command. I’ve reported that as RH-86169 ClippingDrawings: Background Object Only Partially Drawn
If you see something else, please point that out on an image.
Thanks,
