Rhino 8: Polyline drawing lags behind the cursor
As long as I remember I had this problem in Rhino 8, I don’t recall if I reported it already. Since we are out of beta, I hope to get rid of it and be able to draw lines as smoothly as in Rhino 7.
Growing lag when drawing quickly is clearly visible, less visible but something I can see and feel is less smooth line movement when I orbit the cursor.
Hi @Czaja,
Can you run Rhino’s SystemInfo command and post the results?
Thanks,
– Dale
Of course, forgot to post it. Sorry.
System Info
Rhino 8 SR2 2023-11-29 (Rhino 8, 8.2.23333.09481, Git hash:master @ f86ef9263572569e355077b20611612127c1a79a)
License type: Evaluation, build 2023-11-29
License details: Cloud Zoo
Expires on: 2024-01-30
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.11
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-4-2023
Driver Version: 31.0.15.3758
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\23.3.0.0\bella_rhino.rhp “Bella” 23.3.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.2.23333.9481
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.2.23333.9481
Thanks @Czaja. I’ve opened a issue so we can evaluate this.
https://mcneel.myjetbrains.com/youtrack/issue/RH-78699
– Dale
Hi @Czaja ,
I can clearly see the difference in your video, but I cannot duplicate it here…although I’m running a significantly faster configuration atm.
What happens if/when you turn off (hide) Rhino’s status bar and then try the same test? I ask because it has been the cause of many of these types of issues over the course of the V8 cycle, and we’ve been optimizing each one as we come across them… But since I can’t reproduce the problem, I cannot confirm that the status bar updates are the cause… So please let me know if this makes any difference and we can go from there…
Thanks,
-Jeff
Also @Czaja ,
What type of input device are you using? Standard Mouse? Wacom Tablet? ???
-J
Hi Jakub - does it make any difference if no osnaps are enabled?
I think we found the culprit…
It looks like it’s the command prompt that’s causing the lag… And you can’t just hide it (because it still exists, you just can’t see it)… You need to hide it, then restart Rhino…but once you show it again, the problem will return and remain…until you redo the above.
Obviously this isn’t a solution or even a workaround…I’m only stating our findings atm…I will continue digging into this to see if I can figure out what the command prompt is doing differently than it does in V7.
Thanks,
-Jeff
Fullscreen viewport or turning off Osnaps as Pascal suggested makes no difference. I’m using a Razer Orochi V2 mouse without any dedicated software, I don’t have any other mouse to test but thanks to chunky touchpad buttons I was able to test it using the touchpad, and it’s the same… If you want I can grab a Wacom Intuos tablet, but it’s in my drawer somewhere, so only if necessary :wink:
Anyway, you are right about restarting Rhino without the command prompt it is “solving” the problem on my machine too.
No sense grabbing a Wacom tablet since we can see it here, too. Thanks.
@Czaja are you still seeing this bug in Rhino 8? I’m having a heck of a time trying to repeat it. If you are still seeing this bug, does it also happen in the curve command?
Hi, unfortunately, it’s still there in Rhino 8.8.24125.2001 while using the Curve or Polyline command.
System Info
Rhino 8 SR8 2024-5-4 (Rhino 8, 8.8.24125.02001, Git hash:master @ 5c236d89b9c976d469def9a37e9a1417046c1d19)
License type: Educational, build 2024-05-04
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
C:\Program Files\Rhino 8\Plug-ins\RhinoToGrasshopper\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24125.2001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24125.2001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24125.2001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24125.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24125.2001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24125.2001
I’ve been posting about this for a while.
I made some optimizations to the polyline command that hopefully will fix this. This fix will be in the Rhino 8.8 release candidate which we will begin shipping next week.
RH-78699 is fixed in Rhino 8 Service Release 8 Release Candidate 1. Please give it a try.
@Czaja and @anon please test the 8.8 release candidate. I think I made this faster, but without really being able to reproduce the bug I am only guessing at this point.
Thanks,
-Steve
Sorry to say that but it’s still there and I didn’t notice any difference in speed.
Thanks. After installing 8.8.24135.14001 yesterday, the first run of the Polyline command started with a spinning blue cursor for a moment, and I haven’t seen that in subsequent trials. In my case, the lag is slightly reduced but it is still pronounced.
SystemInfo-R8
Rhino 8 SR8 2024-5-14 (Rhino 8, 8.8.24135.14001, Git hash:master @ 8c191427bc5c6c4e62f523a752d809f68897c3a5)
License type: Commercial, build 2024-05-14
Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24135.14001
@stevebaer what’s odd is that I don’t see any lag and have the same rtx a3000 as @Czaja is using.
@Czaja to be sure: does it behave the same without the 3rd party plugins?
Does the display get slower as you add more points to the polyline or is it continuously the same level of slow?
