Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-1-2023
Driver Version: 31.0.15.3799
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
.NET 7.0.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
hi @anon I would try updating your display driver to see if that makes any difference. Since we cannot reproduce it, there is nothing yet we can do about it.
Make sure to perform a clean installation of the drivers.
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z:\Shared\Library\Software\Rhinoceros\Others\MultiViewCapture.rhp “MultiViewCapture” 1.0.0.0
One more thing I would like to try, can you run _Reset and hit the Save settings for support… and send that to me. And as well run OptionsExport and send the resulting ini to me?
I think I tried everything I can think of to reproduce, but still cannot. The only big difference I see is that you are running Windows 10, but I can hardly believe that could be it.
I loaded your settings but that did not change anything.
I can reproduce it here with R8 SR5 if i click new polylines points very very fast, then it noticably lags behind to connect them. R7 does not have this. Would have never noticed it while clicking with normal speed.
Yeah, I can see a tiny bit of lag here when I click polyline points as fast as my index finger can go - I estimate it’s maybe a tenth of a second or two behind the click and I see the last segment drawn a fraction of a second after I stop - however nothing near what the video above shows. And I have to click so fast I would never hit any object snaps or anything else accurately. If I make a polyline at a ‘normal’ speed (for me) I don’t see any delay.
