Rhino 7 is lagging / slow
Hi Everyone.
Is anyone having Rhino 7 lagging this last couple days?
It lags when selecting objects, any object.
When rotating and panning views.
I have my own pop up toolbar and it also lags when opening and selecting a tool…
I updated my graphics card, OS and Rhino and is not getting better.
Cheers.
Hello- please run the SystemInfo command in Rhino and copy/paste the results here.
Hello Pascal,
Here it goes…
Rhino 7 SR17 2022-4-12 (Rhino 7, 7.17.22102.05001, Git hash:master @ 13b57035af8fb22da005ef72c56e4555d9dbcfe3)
License type: Commercial, build 2022-04-12
License details: Cloud Zoo
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
D:\Downloads\Lightmap Tugnstone\HDRI Light Studio Plugins Win64\Rhino3D\Rhino_6_Win_2018.1130\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Grasshopper Gold\food4rhino\plugin Rhino\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\toonf\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\1.0.0\Substance.Win.rhp “SubstanceImporter” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22102.5001
C:\Users\toonf\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
I had Bongo 2.0 evaluation installed but I turned it off since I was getting a missing toolbar message at Rhino start. Not sure if that helped… I’m still trying things.
Hello - the likley suspects are the plug-ins listed under ‘Plug-ins that do not ship with Rhino’
I would disable all of these in Options > Plug-ins page and then close and re-open Rhino. Make sure to have only one session of Rhino open when you do this. If things improve, you can re-enable and load these plug-ins one by one to see if you can tell which one causes the problem.
Hi Pascal,
In the end uninstalling Bongo trial worked.
Thanks!
Hm! Interesting… thanks for the update.
Welcome!
@pascal
Hello, I have the issue about the running slow in Rhino 7.
My systeminfo is copied below, could you help me please. Thanks.
My model is about 900MB and the lagging only happened when I open the “Hidden Line” Layers after MAKE2D. If I turn off the “Hidden” layers it will work smooth but I need to adjust the lineworks under “Hidden” layer. If I turn them on, the pan tool will respond slowly, everything will become slow.
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: 教育授权版, build 2023-12-12
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-7-2023 (M-D-Y).
Primary OpenGL: NVIDIA T600 Laptop GPU (NVidia) Memory: 4GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Render version: 4.6
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Total Video Memory: 4 GB
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
Hi All,
I have to express that I’m so stressful with Rhino 7. Especially applying Grasshopper. My Laptop is nearly top Dell Precision but Rhino just can’t make use any of it. It’s just locked up very often and for a long time!.
Hi @Runkang_Liu
I’m seeing definite slowdowns having to do with make2d and it’s line work.
When I use show selected or isolate Rhino takes forever to work I can go a coffee and come back and those commands might be completed. I tested this on two different computers both in win 10 and win 11 and they’re performance becomes pitiful.
If I hide the linework of the make 2d layers then Isolate and show selected goes back to working properly.
RM
