There is an issue with OffsetSRF command in Rhino 8. I’ve seen several forum posts about this issue, but I am adding my encounter with this issue with the list. I am starting with clean geometry, and with just a couple of curve offsets everything stops working unlike in Rhino 7.
Links to other peoples similar issues:
Offset Surface being such a critical command to Rhino I am hoping this can get fixed fast.
Hi Ian - for some reason I am not able to view the clip - but in nay case, it is always best to send us an example file, either here (public) or to tech@mcneel.com if confidential. Please include a link back to this topic in your comments.
Thanks for posting an example file. It is fundamentally the same result whether I offset inwards or outwards. Not an issue with the same commands and process in Rhino 7.
