OffesetOnSrf fails in Rhino8
I’m trying to use OffsetOnSrf component in GH, I’m seeing different results between Rhino7 and Rhino8. In Rhino8 the component fails to generate a valid offsetted curve, from only some sections of the original input, while in Rhino 7 the result is valid.
I tried with different offset values, please check the .gh file attached.
OffsetOnSrfBug.gh (2.3 MB)
Edit: I also tried using the RhinoCommon API in a C# plugin, the result is the same
Any suggestion?
Yes, also happens to me in Rhino 8SR9.
Rhino 7
Rhino 8
Anyone else having this problem? Anyone found a solution?
Hi, thanks for reporting this. I updated the trimming algorithm in OffsetCrvOnSrf for this issue. It looks like this is causing the trim to be incorrect now in this case. I opened a new issue here.
