when i use command “offsetsrf” with outside then error with top result surface. Why this error? Do you help me?
Version 6 SR29
offsetsrf.3dm (288.9 KB)
Version 6 SR29
Thank!
I know it but the problem does not happen old version when solid = no
Hello - as far as I can see the behavior is the same in V5 - to result is cleaner in both if Corners=Round, which is a mre true offset than Corners=Sharp.
Right. It is cleaner with Corners = Round but it not for the material thickness.
