please help fix this in rhinoceros? Video_2021-11-01_231902.rar (2.7 MB)
Hello - please post a Rhino file that shows the problem.
Hello - set Solid=Yes for now, followed by MergeAllCoplanarFaaces
. If you need the separate shell, you can ExtractSrf
the thin edge surfaces.
@noithatchiaki - setting Corners=Round will also allow that non-solid offset to work correctly.
RH-66156 OffsetSrf - leaves gaps
thank you i will try.
thank you i tried how to make you guide, but to get a new shell inside, it takes quite a few steps?
