Rhino 8 Command OffsetSrf issue
Hi, All
When I using the OffsetSrf command in Rhino 8, I got the wrong result. In Rhino 7, the result was correct.
Step:
  1. Loft
  2. OffsetSrf
    Select object to flip direction. Press Enter when done ( Distance=0.5 Corner=Round ThroughPoint Solid=Yes Loose=No Tolerance=0.01 BothSides=No DeleteInput=Yes FlipAll )
The following is a comparison:
Rhino 7
Rhino 7
Rhino 8 (Version 8 SR5 (8.5.24072.13001, 2024-03-12))
Rhino 8
3dm file(Already saved as Rhino 7 version.)↓
offsetsrf_V7vsV8.3dm (48.7 KB)
Hello- it’s hard to tell what you are pointing out here - as far as I can see offset, in either direction, produces the same results in each version.
Hi,Pascal
Thank you for your response.
When using this file and performing the same operation, Rhino 8 generates a broken surface after executing OffsetSrf.
I don’t know what caused it.
v7 thickens it, v8 shoots the offset into the distance. Very different result in those videos.
Hi @Ansen.A
Don’t ask me why, but it seems to be a tolerance issue. If you increase your tolerance to 0.001 meters, it works in V8. Although I should think there’s nothing in that shape that should require a tighter tolerance. It’s a fairly simple surface, but I’m no NURBS brain, so hopefully someone will chime in and correct me :slight_smile:
HTH, Jakob
Yes, but this is normal in Rhino 7, so I find it very strange.
thanks @Ansen.A this looks buggy in Rhino 8 indeed.
RH-81076 OffsetSrf: wrong result
