Rhino 8 linetypes always print as continuous
Hello!
I have created a drawing in Rhino 8 but when I try to print it (Rhino PDF) the linetypes don’t print, they are all continuous lines. I spent a lot of time trying to change the setting and nothing worked. Finally, I made a Rhino 7 copy and printed the layout with the exact same settings and it worked.
I will attach both the PDFs and the Rhino files.
Rhino 7 print.pdf (390.4 KB)
Rhino 8 print.pdf (423.7 KB)
Rhino 7 copy.3dm (7.0 MB)
Rhino 8 original.3dm (6.3 MB)
Hello.
I have same problem. My drawings had created and printed Rhino7 without any problem 6 months ago. But now with Rhino8 they are printed as all linetypes are overscaled. I tried all combinations of print settings.
Hi Ion -
There are 3987 curves in this file and all layers are set to use the Continuous linetype. There are 6 curves that override this and use the Dashed linetype. Those also override the individual linetype scaling. Because of this, only 1 curve actually shows the linetype pattern. Looking at this file here in Rhino 8.7, everything appears to be as expected.
Hi Boa - please run the Rhino SystemInfo command and copy-paste the result here. Also, if you can export, for example, a single curve that misbehaves on your side, please also post that 3dm file.
