RHINO 8 print PDF linetype scale can’t scale
RHINO 8 print PDF linetype scale can’t scale . RHINO 7 is ok.
Many people have this problem.They won’t all use RHINO PDF.This problem is troubling my work.THANKS!
Hi -
I really don’t know what you are showing in that picture.
How is Grasshopper involved?
FWIW, a dashed rectangle ending up as a continuous curve in a PDF can also be RH-79523 Print: Vector PDF draws hidden linetype curves as continuous
@WATER85 please post this very simple grasshopper definition that works in Rhino 7 but does not work in Rhino 8. We can use that file to try and figure out what the bug is that you are seeing.
Thanks,
-Steve
