Linetypes display incorrectly
There seems to be some problems with how linetypes are displayed. Linetypes display incorrectly but in this case when printing out everything is fine in the pdf. Here’s a simple default file where I have drawn a 10 000mm rectangle offset it in 200mm, set the linetype as dash dot and set the global linetypescale to 100. The scale in the detail view is 1:100. Model view and layout view look the same (wrong), printed pdf looks fine.
I have some more problems printing out layouts with correct linetypes in Rhino 8 if I import to Rhino 7 they work fine. But we may start with this bug…
Print is done with Rhino PDF and bug is both in SR5 and latest SR6.
Broken linetypes.3dm (44.6 KB)
Broken linetypes.pdf (9.4 KB)
Hi -
We have this issue on the list as RH-73669 Dashes: keep alignment of same line pattern
Good to hear, thank you sir!
Our CNC customers will also share this concern.
@wim Glad to see your comment that ExtractLineTypeSegments provides correct result - so at least they will cut correctly :slight_smile:
Can we get a file and set up steps to see this? We will compare to Rhino 7 and log a bug.
Also open Rhino and SystemInfo. Copy and paste the results here.
Thanks for your help.
Sincerely,
Mary Ann Fugier
Sorry I forgot to answer you.
These are the steps after opening Rhino:
  1. Rectangle on origo, 10000 units sides
  2. Offset rectangle 200 units inside
  3. Change linetype of both curves to DashDot
  4. SetLinetypeScale to 100
    Linetype bug RH7.3dm (36.9 KB)
    Linetype bug RH8.3dm (40.4 KB)
    Systeminfo RH8.txt (2.0 KB)
    Systeminfo RH7.txt (2.1 KB)
Hi @Keskinen.
Thank you for the files.
I will looking to this now.
Sincerely,
Mary Ann Fugier
There are more problems with Linetype display.
See this image of Layout viewport after working a while with the file.
Same corner after closing Rhino and reopening the file. It will last for a while and after that the display of the linetypes start failing.
Hope this can be solved somehow.
Thanks
/Erik
