Apologies if this has come up elsewhere, I couldn’t find it in the search.
I’m trying out Rhino 8 and am setting up some Layouts. I have some Leaders already, but when I adjust the Detail, the Leaders don’t adjust accordingly the way it does in 7. Is there a setting that I need to change? I looked through the Leader settings, but didn’t see anything that seemed to address it.
Thanks in advance
Hi Hannah - probably best to post a simple file with the leader that does not work for you - there are a lot of variables…
After trying it out on a few different objects, it seems to be happening with blocks- I didn’t realize before because I had so many blocks in the file I was in.
Leader Test.3dm (968.0 KB)
