Dimensions / text oddities
This is on 8.20.25133.14001, 2025-05-13 I’m seeing dimensions, leaders, and text behaving oddly after double clicking into and out of a detail.
In a new file, create some geometry in model space, switch to layout, create a detail, double click into the detail, then double click back out. Over here, I now cannot place text or a leader (it will let me start, but when I hit Enter, the leader / text disappears). I can also no longer double click to edit dimensions (double clicking text to edit seems to work however).
Thanks,
Sam
hi @SamPage I could not reproduce with the instructions given.
pls run _SystemInfo and post back the results
Hi @Gijs OK, that was a terrible report on my part (end of day, and I thought I had the trigger, but wasn’t even close). Doesn’t matter what space, model or layout, details don’t have anything to do with it, just try placing more than 16 leaders. Over here it will fail on attempt 17. Systeminfo below.
Thanks,
Sam
Rhino 8 SR20 2025-5-13 (Rhino 8, 8.20.25133.14001, Git hash:master @ 007e608777fd819d8976799b8426698dff88c962)
License type: Commercial, build 2025-05-13
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.15
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 5-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.52
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-14-2025
Driver Version: 32.0.15.7652
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.5.1.0
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Users\Samuel\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.20.25133.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.20.25133.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.20.25133.14001
C:\Users\Samuel\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.20.25133.14001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.20.25133.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.20.25133.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.20.25133.14001
In the meantime, is there a way to roll back to 8.19? When I download it, the installer says I already have a newer version installed.
Thanks,
Sam
I am having a similar problem where additional leaders aren’t able to be created.
System Info
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.16
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 4-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.02
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-12-2025
Driver Version: 32.0.15.7602
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Users\ssommerville\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.20.25133.14001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.20.25133.14001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.20.25133.14001
As the file I’m working on is proprietary, I’ll send it to tech@mcneel.com and link to this thread.
Hi Sam,
We can duplicate the issue and will get it logged.
@ssommerv Thanks for emailing the file to support.
We will look at it soon.
Sincerely,
Mary Ann Fugier
While we’re figuring this out, a workaround is to run the -Leader command instead of Leader.
Hi Sam -
You’d need to uninstall 8,20 and then install 8.19.
But, perhaps with the -Leader work-around you can stay on 8.20…
There is something seriously wrong, in one file, I could still create leaders because there were less than 16 of them, but I couldn’t change the arrow type of leaders nor dimensions. I then tried to copy all dims and leaders from that file into a new file and when I tried to change arrow of a leader to a user defined block, Rhino straight up crashed. I can’t replicate it now because the conditions for that seem to be very particular but I sent a crash report when it happened with the file attached.
Hi Simon -
Yes.
This issue was put on the list as RH-87550 [Crash creating 17th leader] (not sure why it was not set to be visible to the public).
This has since been fixed and the next 8.20 candidate will contain that fix. For now, you should probably revert to 8.19.
RH-87550 is fixed in Rhino 8 Service Release 20
