Rhino 8 freezing - VA3, tibidabo clash with blockedit?
Hi There,
I am having issues with a file in rhino 8 where using blockeditnew on a block when i save it or try to add something rhino 8 freezes and becomes unresponsive.
I can open use blockedit successfully in safemode with all other plugins disabled.
I am assuming something like visual arq 3 or tibidabo is clashing with it.
I clean installed by gpu driver.
Repaired rhino 8 install.
Other files work but not this one.
I assume it is something to do with the block manifest maybe. Any way someone can help fix this please.
I also down saved to rhino 7 and i can now edit blocks, although none of the visualarq 3 objects have come across. So it could be va3 interacting with the blocks.
Sysinfo-
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13001, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commercial, build 2024-06-18
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.5
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 Ti (NVidia) Memory: 12GB, Driver date: 7-10-2024 (M-D-Y). OpenGL Ver: (null)
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 7-10-2024
Driver Version: 32.0.15.6070
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
Total Video Memory: 12 GB
C:\Users\hicko\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew_V8.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24170.13001
audit:
Document Manifest:
Texture Mapping: 20 active, 1 system.
RenderMaterial[175] name missing from document manifest.
Material: Error: differences between model table[175] and manifest information.
RenderMaterial[176] name missing from document manifest.
Material: Error: differences between model table[176] and manifest information.
RenderMaterial[177] name missing from document manifest.
Material: Error: differences between model table[177] and manifest information.
RenderMaterial[178] name missing from document manifest.
Material: Error: differences between model table[178] and manifest information.
RenderMaterial[179] name missing from document manifest.
Material: Error: differences between model table[179] and manifest information.
RenderMaterial[180] name missing from document manifest.
Material: Error: differences between model table[180] and manifest information.
RenderMaterial[181] name missing from document manifest.
Material: Error: differences between model table[181] and manifest information.
RenderMaterial[182] name missing from document manifest.
Material: Error: differences between model table[182] and manifest information.
RenderMaterial[183] name missing from document manifest.
Material: Error: differences between model table[183] and manifest information.
RenderMaterial[184] name missing from document manifest.
Material: Error: differences between model table[184] and manifest information.
RenderMaterial[185] name missing from document manifest.
Material: Error: differences between model table[185] and manifest information.
RenderMaterial[186] name missing from document manifest.
Material: Error: differences between model table[186] and manifest information.
RenderMaterial[187] name missing from document manifest.
Material: Error: differences between model table[187] and manifest information.
RenderMaterial[188] name missing from document manifest.
Material: Error: differences between model table[188] and manifest information.
RenderMaterial[189] name missing from document manifest.
Material: Error: differences between model table[189] and manifest information.
RenderMaterial[190] name missing from document manifest.
Material: Error: differences between model table[190] and manifest information.
RenderMaterial[191] name missing from document manifest.
Material: Error: differences between model table[191] and manifest information.
RenderMaterial[192] name missing from document manifest.
Material: Error: differences between model table[192] and manifest information.
RenderMaterial[193] name missing from document manifest.
Material: Error: differences between model table[193] and manifest information.
RenderMaterial[194] name missing from document manifest.
Material: Error: differences between model table[194] and manifest information.
RenderMaterial[195] name missing from document manifest.
Material: Error: differences between model table[195] and manifest information.
RenderMaterial[196] name missing from document manifest.
Material: Error: differences between model table[196] and manifest information.
RenderMaterial[197] name missing from document manifest.
Material: Error: differences between model table[197] and manifest information.
RenderMaterial[198] name missing from document manifest.
Material: Error: differences between model table[198] and manifest information.
RenderMaterial[199] name missing from document manifest.
Material: Error: differences between model table[199] and manifest information.
RenderMaterial[200] name missing from document manifest.
Material: Error: differences between model table[200] and manifest information.
RenderMaterial[201] name missing from document manifest.
Material: Error: differences between model table[201] and manifest information.
RenderMaterial[202] name missing from document manifest.
Material: Error: differences between model table[202] and manifest information.
RenderMaterial[203] name missing from document manifest.
Material: Error: differences between model table[203] and manifest information.
RenderMaterial[204] name missing from document manifest.
Material: Error: differences between model table[204] and manifest information.
RenderMaterial[205] name missing from document manifest.
Material: Error: differences between model table[205] and manifest information.
RenderMaterial[206] name missing from document manifest.
Material: Error: differences between model table[206] and manifest information.
RenderMaterial[207] name missing from document manifest.
Material: Error: differences between model table[207] and manifest information.
RenderMaterial[208] name missing from document manifest.
Material: Error: differences between model table[208] and manifest information.
RenderMaterial[209] name missing from document manifest.
Material: Error: differences between model table[209] and manifest information.
RenderMaterial[210] name missing from document manifest.
Material: Error: differences between model table[210] and manifest information.
RenderMaterial[211] name missing from document manifest.
Material: Error: differences between model table[211] and manifest information.
RenderMaterial[212] name missing from document manifest.
Material: Error: differences between model table[212] and manifest information.
RenderMaterial[213] name missing from document manifest.
Material: Error: differences between model table[213] and manifest information.
RenderMaterial[214] name missing from document manifest.
Material: Error: differences between model table[214] and manifest information.
RenderMaterial[215] name missing from document manifest.
Material: Error: differences between model table[215] and manifest information.
RenderMaterial[216] name missing from document manifest.
Material: Error: differences between model table[216] and manifest information.
RenderMaterial[217] name missing from document manifest.
Material: Error: differences between model table[217] and manifest information.
RenderMaterial[218] name missing from document manifest.
Material: Error: differences between model table[218] and manifest information.
RenderMaterial[219] name missing from document manifest.
Material: Error: differences between model table[219] and manifest information.
RenderMaterial[220] name missing from document manifest.
Material: Error: differences between model table[220] and manifest information.
RenderMaterial[221] name missing from document manifest.
Material: Error: differences between model table[221] and manifest information.
RenderMaterial[222] name missing from document manifest.
Material: Error: differences between model table[222] and manifest information.
RenderMaterial[223] name missing from document manifest.
Material: Error: differences between model table[223] and manifest information.
RenderMaterial[224] name missing from document manifest.
Material: Error: differences between model table[224] and manifest information.
RenderMaterial[225] name missing from document manifest.
Material: Error: differences between model table[225] and manifest information.
RenderMaterial[226] name missing from document manifest.
Material: Error: differences between model table[226] and manifest information.
RenderMaterial[227] name missing from document manifest.
Material: Error: differences between model table[227] and manifest information.
RenderMaterial[228] name missing from document manifest.
Material: Error: differences between model table[228] and manifest information.
RenderMaterial[229] name missing from document manifest.
Material: Error: differences between model table[229] and manifest information.
RenderMaterial[230] name missing from document manifest.
Material: Error: differences between model table[230] and manifest information.
RenderMaterial[231] name missing from document manifest.
Material: Error: differences between model table[231] and manifest information.
RenderMaterial[232] name missing from document manifest.
Material: Error: differences between model table[232] and manifest information.
RenderMaterial[233] name missing from document manifest.
Material: Error: differences between model table[233] and manifest information.
RenderMaterial[234] name missing from document manifest.
Material: Error: differences between model table[234] and manifest information.
RenderMaterial[235] name missing from document manifest.
Material: Error: differences between model table[235] and manifest information.
RenderMaterial[236] name missing from document manifest.
Material: Error: differences between model table[236] and manifest information.
RenderMaterial[237] name missing from document manifest.
Material: Error: differences between model table[237] and manifest information.
RenderMaterial[238] name missing from document manifest.
Material: Error: differences between model table[238] and manifest information.
Material: Error: 64 errors found. Model: 175 active, 0 deleted. Manifest: 239 active, 0 deleted.
Line Pattern: 7 active, 3 system.
Layer: 45 active, 1 system.
Group: none.
TextStyle: none.
Annotation Style: 2 active, 12 system.
Light: none.
Hatch Pattern: 12 active, 9 system.
Block: 60 active.
Model Geometry: 637 active, 1 deleted.
Error: 959 model components (1 deleted). 28 system components. 1051 manifest items
Audit Summary:
0 object errors detected.
0 linetype table errors detected.
0 layer table errors detected.
0 block table errors detected.
0 font table errors detected.
0 annotation style table errors detected.
Table tally:
45 layers
60 instance definitions
2 annotation styles
0 fonts
7 linetypes
239 rendering materials
Object tally:
106 normal objects
0 locked objects
0 hidden objects
1 deleted objects (in undo buffer)
531 block definition objects
0 reference normal objects
0 reference locked objects
0 reference hidden objects
0 reference block definition objects
Audit found problems.
