Block Editing while in Raytraced makes rhino crash
Not sure if this is a known issue.
Steps:
  1. Make a cube
  2. Make it into a block
    2b. Copy that block over (Not sure if this is necessary)
  3. Turn on raytraced
  4. Run BlockEdit and move a face of the cube
  5. Crash
@nathanletwory probably?
Hello - thanks for the report - I do not get a crash here so far, but raytrace certainly does not keep up with the edits to my box - that much at least I can add to the bug tracker.
RH-64729 Cylces: Keep up with blockEdit
Please send in a crash report if you can, just in case we cannot repeat the crash here.
I also am not able to reproduce the crash. But the problem is BlockEdit: RH-47128 BlockEdit messes with object attributes (instance).
Thanks.
At least two of our computers crash when doing this, but they are setup almost identically. There should be a couple of crash reports.
Can you please share a file with me with which the crash happens on your machines? You can use rhino3d.com/upload?to=nathan@mcneel.com to upload confidentially. I’ll be notified automatically when the upload has completed.
@rheinason also, could you please share in a private message with me what e-mail address(es) you have used to submit the crash reports? The one I can see here on discourse does not find any crash reports.
There not really any file, it’s basically just doing the steps above. I just caused a crash and sent the report, did you receive it?
I have repeated the steps many times, and was not able to cause a crash. Can you please copy&paste the result of the Rhino command _SystemInfo here?
System Info
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05001, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Commercial, build 2021-06-09
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
  Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 1-22-2021
  Driver Version: 27.21.14.6140
  Z-Buffer depth: 24 bits
  Total Video Memory: 8 GB
  C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\ColorPicker (336da4ab-03d3-42ca-b1fb-313bfd4c1157)\2019.2.15.811\ColorPicker.rhp	"ColorPicker"
  C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp	"ClippingBox"	1.0.0.0
  C:\Users\User\AppData\Roaming\Grasshopper\Libraries\elefront421\ElefrontProperties.rhp	"ElefrontProperties"	1.0.0.0
  C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp	"SpeckleRhino2"	2.1.22.5474
  C:\Users\User\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll	"Enscape.Rhino7.Plugin"	0.0.21124.1031
  C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\ConnecterPlugIn (caac53be-e271-4b97-93e7-f3dd18d48ccc)\0.5.0.0\ConnecterPlugIn.rhp	"ConnecterPlugIn"	0.5.0.0
  C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp	"Twinmotion Direct Link 2020"	1.0.6.0
  C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp	"NVIDIADenoiser.Windows"	0.4.0.0
  C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp	"RhinoPbrMaterial"	1.1.2.0
  C:\Program Files\Rhino 7\Plug-ins\Commands.rhp	"Commands"	7.7.21160.5001
  C:\Program Files\Rhino 7\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	7.7.21160.5001
  C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	7.7.21160.5001
  C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp	"Renderer Development Kit UI"
  C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	7.7.21160.5001
  C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	7.7.21160.5001
  C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp	"Displacement"
I tried disabling Tibidabo and VisualARQ, but I still got the crash, but they might still be related, a coworkers computer didn’t crash and he doesn’t have VisualARQ.
Calling @fsalla
You have also quite many other plug-ins (twinmotion, enscape, speckle, etc). It would be good to start by load-protecting those as well, restart Rhino and see if you still can crash Rhino.
If that works, then load plug-ins one by one, each time seeing if you can reproduce the crash. Take note of when the crash starts happening again.
Unrelated: you don’t need the rhinopbrmaterial plug-in anymore, it was more intended for Rhino 6 where there wasn’t a PBR-based material yet. In Rhino 7 there is a native Physically Based Material. Use that instead.
Indeed, consider that cleaned up! :slight_smile:
I unloaded all plugins and the crash persists
System Info!
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Render version: 4.6
Please set me know what e-mail address you filled in with the reports. Or if you didn’t do that please paste the link to this discussion in the comments section before submitting the crash report. Anything that helps me find your crashes.
I have found two crash reports, I’m looking into them now.
Might be a bit closer, updated my Graphics Driver and now I don’t crash but get a server busy message the first time around, and then crash.
The crash dumps show they are related to a YT item I’m currently working on:
RH-64450 rhcommonrdk_c!ContentDatabaseEventInfo_Content – Access Denied (hidden from public).
I have not been able to reproduce this myself yet.
The crashdumps that I already found from you @rheinason have still all the plug-ins loaded. I hope the last one you sent in with all the 3rd party plug-ins disabled helps a bit more in determining what the problem is.
added: @rheinason for the record: for what region/locale do you have your Windows configured? I see you have english as language.
@rheinason the latest crash report you sent in still has all the plug-ins loaded. Please load-protect all plug-ins that do not ship with Rhino and restart Rhino. Also please don’t start Grasshopper before you redo your test.
Yeah windows gets a bit annoying, some parts are in Danish and some in English.
Ok, I have my own region set to Finland, maybe not related to this error.
