Rhino 8.10.24228.13001 crashes when copying blocks
Does anyone knows why rhino 8 crashes when i am trying to copy a block ?
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
It looks like you have narrowed it down to VisualArq?
Yes something is happening with visualArq. I tested in safe mode and also in normal mode with visualArq disabled.
Rhino 8 SR10 2024-8-15 (Rhino 8, 8.10.24228.13001, Git hash:master @ f4c93f2b85de4dc69b50ed22f1b0d91445724d03)
License type: Educational, build 2024-08-15
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [79% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 3-8-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2024
Driver Version: 32.0.15.6081
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\Vector\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.2.0
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\1.0.8405.22062\TeDaSharp_060.rhp “TeDAsharp” 1.0.8405.22062
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24228.13001
Fixed with the update to SR11 RC4
Sorry to reopen this issue, but I’m not super technical with system info. I’m having the same issue: Rhino crashes when attempting to copy blocks. I see the solution is update to SR11 RC4, but I don’t know what that means. System Info below:
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13001, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Educational, build 2025-02-11
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.20
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-3-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-26-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 565.90
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-26-2024
Driver Version: 32.0.15.6590
Total Video Memory: 8 GB
C:\Users\whbro\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.25042.13001
Hi whb -
You are running SR 16, so the fix that went into SR 11 is also in the version that you are running. That means that you are likely running into something different.
Is this file-specific or does that also happen when you start a new file from a factory-default template, draw a rectangle, turn that into a block, and “copy” (you’ll also need to be more specific about what, exactly, that means) this block?
Gotcha, that makes sense.
In terms of the issue being file specific, based on the scenario you laid out, I’m guessing it might be. I created a new file, made a box, made that box into a block, then copied it with the “Copy” command with no issue. In the file were the issue occurs, blocks that I try to copy via the “Copy” command crash Rhino when I specify the base point (point to copy from) for the copy. As soon as I click to specify that first point, Rhino crashes.
block copy test.3dm (135.9 KB)
I exported one of the blocks that causes the crash to it’s own Rhino file and the behavior persists. As far as I can tell, all blocks cause the crash, but I just chose one to export.
Thanks for that file.
I couldn’t get that to crash Rhino here though.
When Rhino crashes, does the crash reporter dialog come up? If it does, please always send those in as they provide valuable information for the developers. I’m not seeing any such reports from the eMail address that you use here though.
Does disabling that plug-in in the Rhino Plug-in Manager and then restarting Rhino make a difference?
Hmm, interesting.
Unfortunately, the crash reporter dialog does not show up; Rhino just spins for a few minutes, then suddenly closes.
I disabled the Lumion plug-in and restarted, but Rhino still crashes when the block is copied.
Hi -
Could you provide a manual dump file from when Rhino is in this just spinning stage? Instructions for creating and sending those can be found here: Manually Creating a Memory Dump (DMP File) from an Unresponsive Rhino for Windows [McNeel Wiki]
Roger that, just uploaded the ZIP file through the link you sent. That is one chonker of a file!
Hi all,
I’m having the same problem with blocks and I’m running Rhino 8 SR16. @wim Any update about this issue?
When I try to copy a very simple block made of a bunch of surface and lines (as a simple example), Rhino freeze. I exported the block using the export selected function and when I open the file of the exported block I get the same behavior.
I attached the file with the block; @wim it would be great if you could test if you get the same behavior on your end.
treeBlockTest.3dm (68.9 KB)
Thank you very much.
Paolo
Small update. I managed to isolate the problem, and it looks like it is display mode dependent. if I copy the block in wireframe mode, it works fine, if I do it in rendered mode (or any display mode I created as a copy of the the rendered mode) Rhino throws a tantrum. I updated my Nvidia graphic card and sent the file to a few colleagues and we all get the same issue.
Let me know if you get a change to test the file.
Thank you!
Paolo
Hi Paolo -
That works fine here in 8.24.
Please run the Rhino SystemInfo command and copy-paste its output here.
@wim Thanks for the prompt response, much appreciated.
System info below:
License type: Commercial, build 2025-02-11
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 6-4-2025 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
  • Windows Main Display attached to adapter port #2
    Primary OpenGL: NVIDIA RTX A2000 8GB Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-29-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 573.73
Integrated accelerated graphics device (shares primary device ports)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 8-29-2025
Driver Version: 32.0.15.7373
C:\ProgramData\Beam\App\RHINOBEAM.dll “MKS BEAM” 1.10.4.0
C:\Users\alborghettip\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Walkie\4.14.0.0\Walkie.rhp “Walkie” 4.14.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.8.0.723
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
Hi Paolo -
The first quick check would be to disable those plug-ins and restart Rhino. Does Rhino still crash when having done that?
Apart from that, the current stable version of Rhino is 8.23. Can you get that installed to see if that fixes things?
I see one crash report from you, but don’t know if that was related to this issue?
Please continue to send in all crash reports. Adding a comment about what you were doing at the time of the crash is always helpful.
