just downloaded purchased and installed 8 - keep seeing this when trying to save
ive tried to save to different locations and file names…
now i can’t save anything
@pascal any ideas?
Hello - no ideas, @brian - do you have an idea? this one is new to me.
@zale_orcid do you have some file utilities or anything running? I might try, just a shot in the dark, running a repair on the Rhino installation.
Please try this:
- Tools > Options > Advanced
- Search for “tempfile”
- Set “Rhino.Options.FileSettings.WriteLocalTempFileWhenSaving” to “False”
Does that fix it?
If so, you may not have permissions to save to your local TEMP folder, for some reason.
Is that still on the C: drive? Or other drive(s) in your computer? Or also on network drives? Is it just Rhino or might you have problems with other apps?
If just on your PC and not Rhino specific I’d check for a corrupted file system and for a failing disk controller or failing drive hardware.
Hey all thank you, left the office for the day, I’ll follow up with this tomorrow
