Rhino 8 does strange things
Hi there
please watch this video.
LINK
are solids not suppose to have vectors at the edges in whireframe mode (and also shaded). also when i draw curves, circles etc. they just disappear.
yes. i made updates. reboot the pc etc. but it did not help.
thanks
michael
Hi Michael, please run SystemInfo in the Rhino command line and post your results.
Does running the Reset command (to factory settings) change the behavior?
hi japhy. thanks for replying. here is the systeminfo.
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Lab-Lizenz, build 2024-04-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX 570 Series (AMD) Memory: 8GB, Driver date: 3-30-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 22.20.27.09.230330
> Accelerated graphics device with 7 adapter port(s)
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 3-30-2023
Driver Version: 31.0.12027.9001
Z-Buffer depth: 24 bits
Total Video Memory: 16107 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
i also just made the complete reset. the behaviour remains the same. strange, isn’t it?
Can you remove the citrix device?
Is there a newer video driver for that card?
One thing to try on the Radeons is to lower the OpenGL level (or try with GPU tessellation unchecked)
thanks
i will try to update the graphiccard driver
i also could remove citrix since its not working. (its for remote controll of a laser cutter)
if this does not work out i try the open gl settings
is this procedure correct?
Thanks, that is correct sequence. Older Citrix has been known to cause issues (as have some AMD drivers)
thanks a lot. it was the graphic card driver!
cheers
michael
