Hi all,
Basically what the title says. Building a multi-page layout template in Rhino 8, and trying to copy objects between Layouts. I’ve tried Cmd+C and “CopyToClipboard”, but using Paste and Cmd+V yield “Unable to paste, no Rhino objects or text on the Clipboard.”
Hope someone has a fix!
Robert
Japhy
(Japhy)
January 1, 2024, 11:13pm
2
Hi Robert, I’m not able to repeat this, can you try in a new file?
What is your systemInfo look like? (run systeminfo command in the rhino command line)
Thanks
Rhino_SystemInfo.txt (4.7 KB)
Tried again in a new document and still can’t paste. Copying/pasting text works fine, just not rhino objects.
-Robert
wim
(Wim Dekeyser)
January 2, 2024, 8:54am
4
Hi Robert -
Just to make sure, could you post a very simple 3dm file with geometry on one layout that you can’t copy to a different layout?
I am having this same issue. Can’t copy and paste any text, lines or objects between layouts. I can copy and paste within a sheet. Slowing down drawing time by a landslide
I am having the same issue as well
dale
(Dale Fugier)
September 4, 2024, 10:08pm
7
@user384 , @James_Stodgel1 - can you help us repeat this? We could use a file and step-by-step instruction on how to make this not work.
Thanks,
– Dale
Hello, I still have this issue. I have 20 different pages, somehow i cannot copy paste and object on just two of them. It works on the ones. Even after restarting and everything. I have no clue on how to fix this…
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13002, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Commercial, version 2025-02-11
License details: Cloud Zoo
Apple macOS Version 14.5 (assemblage 23F79) (Physical RAM: 32GB)
Mac Model Identifier: Mac14,6
Language: fr-FR (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
LG HDR 4K (3008 x 1692 @ 60.00Hz)
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
VIA Technologies Inc. : USB 2.0 BILLBOARD
Apple Inc.: Apple Keyboard
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/cyriac/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/Enscape.Rhino8.Plugin.rhp “Enscape.Rhino8.Plugin” 4.2.1.88
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rendu de Rhino” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Outils extra pour Rhino” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Ancien rendu de Rhino” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.16.25042.13002
wim
(Wim Dekeyser)
April 24, 2025, 9:17am
9
Hi Cyriac -
It sounds like you have a very reproducible case. Please post or upload the 3dm file and step-by-step instructions on how to repeat this.
wim
(Wim Dekeyser)
April 24, 2025, 12:35pm
10
Hi Cyriac -
Thank you for uploading your file.
In that file, only layout “DETAIL GLASS DOOR” doesn’t show the geometry that you copy-paste to all layouts.
When I then copy-paste that geometry to that layout, I also see that nothing gets added. Checking the layer states on that layout shows that turning on layout “2D” shows the geometry.
