I want to copy parts of my drawing into a different window but each time I try nothing happens???
you are talking about copy breps / polysurfaces (= parts) from one rhino document to another rhino document (“window”) ?)
on mac ?
Rhino 8 ?
EDIT
Version 8 (8.14.24332.15002, 2024-11-27) works fine here.
please post:
- a source file (with the geometry to copy)
- a target file
- your system-info
without providing data that allows to repeat your error its hard to help.
and … did you try a restart of your computer ?
I am using 8.8.13, apparently I am up to date. I was trying to copy a part of my drawing into a new window that was empty of other elements. I am on a Mac. The file is rather big so I would need to send it to you through something other than an email.
J. Neill
Hi Joe -
Please run the Rhino SystemInfo command and copy-paste the output here.
You can upload a file to use from this page - https://www.rhino3d.com/upload
Make sure to copy a link to this topic in the comments field on that page.
Hi Joe -
We need the output of the Rhino SystemInfo command.
Also, I’ve looked at the model you sent but have no problem copying some objects and pasting those into a new blank file. If you have more specific instructions, that would help.
Here it is.
(attachments)
RhinoSysInfo.txt (4.85 KB)
Hello Wim,
Sorry for the late response. The updated version solved the problem of copy/paste. Was it my file or a Rhino bug?
Thanks
Joe
