Copy not working
Rhiino 8 copy/paste doesn’t work.
Copy command triggers a pinwheel, takes 10-30 seconds. CopyToClipboard shows up in my history.
Cmd+V or Paste command yield “Unable to paste, no Rhino objects or text on clipboard.”
However, objects copied from a file in Rhino 7 can be pasted in my Rhino 8 file, but anything copied within Rhino 8 doesn’t work. I’d guess the issue is with copying to clipboard in general. This goes for copying objects in model space (within 1 file or between files), or Layout Space (between layout pages in one file or between files).
I’ve posted about this problem before but since it’s a global issue and not limited to Layouts, I thought I’d repost.
I’d try two things:
  • Restart your Mac
and if that doesn’t sort it…
Any luck?
i have noticed Rhino beeing absurdly slow in some situations, maybe depending on how much geometry is in the file. i noticed sometimes even selecting objects can take quite some time.
but if you have some file which exhibits this issue that would be interesting for the developers you have a look, since you did not post any in the other topic maybe you can this time.
