Rhino 8 bug report: Mouse pointer size change
I have adjusted my pointer size and color through the Windows mouse pointer settings in the control panel, so it always appears green and larger than normal. Whenever I open Rhino, my mouse pointer either becomes pixelated or suddenly becomes super small. To fix it, everytime I have to go to the Windows control panel and reset my pointer settings so that it appears as before.
I assume it is a Rhino issue since it doesn’t happen with other software.
Thanks!
Having the same issue. Some specifications…
  • Mouse pointer gets larger sometimes when I open Rhino8. It never happened in any other software.
  • It started happening when I changed from a Win10 Laptop to a Win11 Laptop.
  • To fix I have to manually adjust pointer size in Windows-Settings each time.
  • Pointer appears normal on Laptop, size change only is visible on external monitors.
  • Rhino Version 8 SR6 (8.6.24101.5001, 2024-04-10)
Current version is 8.12
Windows 11 is notoriously bad at managing multiple monitors, especially if they are different resolutions/display scaling.
Separate from the mouse pointer size issue you may want to get 6 months worth of fixes and improvements to Rhino 8 by upgrading to Rhino 8.12
I totally should. But I am bound to whenever our IT decides to update software packages. Hence I am always a few months behind.
But you are right, reporting bugs on older versions just isn’t as useful. That didn’t cross my mind to be honest…
I have this issue both on Windows 10 and 11 and in a single monitor setup. Just updated to the latest version the problem persists. The issue happens especially when the Rhino file is heavy. Here’s a photo for reference:
