Hi everybody.
Coming fron Rhino 5,I have just install Rhino 8.
But I encounter a problem with the UI: when the mouse cursor move above some buttons, they become blurry or disseaper.
I try to make a sceenshoot with a small window
The 4 cases are gone as the 3 buttons and the text is blurry.
Also look above the clock botton right with a distorded text.
I don’t know if it’s a knowed bug or a problem with my config. I have found nothing similar on the forum.
Win 10 64bits, 1920x1080 monitor.
Thank you for any help.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 8-5-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.68
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-5-2021
Driver Version: 30.0.14.7168
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Hi Pascal and Nathan.
Thank you for your help.
Dowloaded and intalled the latest drivers but no luck. Still the same problem of text going mad.
Here is an another screenshot with distorded text on the bottom toolbar.
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
Hi Wim,
The main screen is 1920x1080, 60 hz, RVB 8bits, 100% scaling.
The second one is 1024x768, 60hz, RVB 8bits, 100 scaling.
Option extended between both.
Eric
