Hi - I continue to get unexpected shadows on simple model surfaces (rendered viewport, Rhino 7, scene lighting, sun setup for Honolulu) that seem to be cast by mysterious “ghost” (nonexistent) geometry. In the following case I’m getting partial shadows within darkened areas already in shadow, however there is no reason these shadows should occur. If anyone knows how to fix this I’d appreciate it. Note in the image attached that there is no other geometry in the scene, just simple floor plate and wall solids. Making me crazy… Thanks
hi @mwinkelstein pls run _SystemInfo in Rhino, and post back the results.
Sure - here it is. Thanks!
Rhino 7 SR32 2023-8-9 (Rhino 7, 7.32.23221.10241, Git hash:master @ 3d9c816c4cd57561d12d8f53246bce304f314ba2)
License type: Commercial, build 2023-08-09
License details: Stand-Alone
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 8-11-2021 (M-D-Y).
> External USB display device with 2 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-19-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 517.66
Secondary graphics devices.
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-26-2022 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-19-2022
Driver Version: 31.0.15.1766
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.2.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.32.23221.10241
Can you post the scene as well? Then I might be able to tweak settings to improve.
In any case, this seems a classic issue with shadow mapping. The larger the scene is, the worse it gets.
Thanks - I’ve tried just about every possible shadow setting (clipping planes, etc.) and find I have this problem with the large model but also the relatively small and simple one posted above. I did, oddly, find I could tweak the Arctic viewport setting to show colors and read similarly to Rendered, and the problem went away. With all settings similar between Arctic and Rendered (lighting, scene, etc.) I found I had to increase the sun intensity to 4x compared to 1x for Rendered, but ended up with a pretty clean result. No idea what is inherently different about Arctic when set to the same settings as Rendered… but the result is far better. Please see following Artic view - no weird shadow artifacts. It seems like there is something with Rendered viewport that is the issue.
