From File menu, go to properties, View, expend Rendered, click Shadows,
On the right you can change few settings for the Shadow, in your case you
The option Self-Shadowing Artifacts, you can bring the slider to the Left
Hi
Thanks for the suggestion, it helps a little but doesn’t solve the problem. The trouble is I keep being fooled into thinking surfaces aren’t meeting. This has been like this for years.
What does your _SystemInfo
in Rhino say?
Yes, true, it helps a little, but not 100%, specifically when the object has no thickness.
I’ve found that in addition to the Self Shadowing option, increasing the Edge Blurring a little +
Increasing Video Memory Usage/Shadow Size, will add to the improvement, but again not 100%
You’ll keep seeing some Artifacts.
Hello Nathan
System inf below:
Rhino 6 SR2 2018-3-6 (Rhino 6, 6.2.18065.11031, Git hash:master @ cd4fa1dcdec31cb58baacef0855771173af7196f)
Windows 10.0 SR0.0 or greater (Physical RAM: 6Gb)
GeForce GTX 650/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 390.77)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-23-2018
Driver Version: 23.21.13.9077
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
