People Hi,
Massive slowdown for me too. On different files. On the perspective view, as I manipulate, It slow down after few minutes of working and then totally freeze. Working on shaded view and with blocks. It turn out that rhino 7 drain all the GPU performance (NVDIA GeForce GTX1060).
I saved my files to R6 and open it under R6, no trouble at all. Very small used of GPU (about 5%).
Wireframe mode appear to be as slow as shaded and when I turn to wireframe, some part stay shaded, as well as when I hide some part, sometime they decide not to.
Rod
Has there been any resolution to this? I’ve noticed what seems to be a similar issue, there’s perhaps a 1s+ lag when selecting lines on a 2D drawing, which is painful to work with.
Hi @ar00302
You are replying to a very old thread, but anyways… Run the SystemInfo Command in Rhino and post the result here. Thay’s the best way of getting the troubleshooting started
HTH, Jakob
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-5-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-1-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.69
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-1-2022
Driver Version: 30.0.15.1169
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\lior marom\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
Hi @lior_marom
What is that is slow? Loading Rhino, screen navigation, interface feedback, specific commands or…?
Anyways, the first thing to do, is to update your graphics card driver. I know it’s not too old, but with Windows updates coming all the time, it’s a good idea to start there. If that doesn’t help, I would try to disable Enscape in the pluginmanager and restart Rhino. If that helps, you need to conctact the Enscape people
HTH, Jakob
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 4-26-2022 (M-D-Y).
> Integrated accelerated graphics device with 5 adapter port(s)
Primary OpenGL: AMD Radeon RX 6600M (AMD) Memory: 8GB, Driver date: 4-26-2022 (M-D-Y). OpenGL Ver: 4.6.14802 Compatibility Profile Context 21.40.56 30.0.14056.7
> Integrated accelerated graphics device with 6 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-26-2022
Driver Version: 30.0.14056.7
Total Video Memory: 8176 MB
Hi @Elaina_Wilson
First thing to do is to update your driver to the latest version and see if that helps. If not, please post a screenshot of your OpenGL settings (Options>View>OpenGL). It might also be worth to take a look at this. I think it’s an Nvidia card, but it might still be relevant.
HTH, Jakob
Hi Jakob, Thanks for that, I updates the driver and it seemed to be working for a bit but has now started to freeze again after only using it for a few minutes, (doesn’t;t come up with not responding error just freezes) I have attached the GL settings below, any help would be great
Hi @Elaina_Wilson
Nothing there looks strange… Make sure that you’re on the latest service release (both Rhino and Win11) - other than that, hopefully one of the bigger brains will chime in (@pascal?)
-Jakob
Try setting Windows 11 to use only the AMD Radeon RX 6600M for graphics in Rhino.
In Windows 11 (not Rhino):
Right click on the taskbar at the bottom of the screen, and then left click on “Taskbar settings”. The Settings panel should open.
or
Click on the Windows icon on the taskbar and select “Settings”. The Settings panel should open.
In the Settings panel search window type “Graphics”. Select “Graphics settings”.
Under “Custom options for apps” select Rhino and click on “Options”.
Chose “High performance” for only the AMD Radeon RX 6600M.
Save
I got also a slow Rhino 7. It freezes and gives the message does not respond and after a few moment it starts again.
Here is my
Sys info.
Rhino 7 SR20 2022-7-12 (Rhino 7, 7.20.22193.09001, Git hash:master @ 9b19bfdb8c343dd6fa8df3514068defd72273d6f)
License type: Commercial, build 2022-07-12
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon RX 6600 XT (AMD) Memory: 8GB, Driver date: 7-25-2022 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 22.7.1.220725
> Accelerated graphics device with 6 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 7-25-2022
Driver Version: 31.0.12015.1008
Total Video Memory: 24256 MB
