Rhino 8 SR27 - The software became slow after the update
I instaled the last service release, and the rhino 3d became extremely slow.
Normaly, when i change the view (like from top to perspective), or from shaded to artic, i have to wait almost a minute, and the file is only 359 mb.
It is possible to install the previous service release ?
Regards,
Sid
HI Sid -
Please run the Rhino SystemInfo command and copy-paste its output here.
Is changing the display mode the only thing that has become slow?
Sending a link in a PM.
Rhino 8 SR27 2025-12-23 (Rhino 8, 8.27.25357.11371, Git hash:master @ 4f7e78056cadbad051d03c30f40683a64dcc7a5d)
License type: Educational, build 2025-12-23
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 15GB)
.NET 8.0.14
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 11-28-2023 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-20-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.07
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-20-2024
Driver Version: 32.0.15.6607
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Users\sidon\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.27.25357.11371
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.27.25357.11371
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.27.25357.11371
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.27.25357.11371
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.27.25357.11371
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.27.25357.11371
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
It goes slow when :
- Opening files
- Changing display mode
- changing from a top view to a perspective view
The view turns black or freezes and takes almost a minute to return to normal in a 90 mb file, in a bigger file it takes more time. Rhino stops responding during this time.
If you want i can send you the rhino file in a private message ?
Hi Sid -
It doesn’t necessarily sound file related.
Both of these could use an update. I’d do a clean install, at least for the drivers for the GeForce.
Does the behavior change when these plug-ins are disabled and Rhino is restarted?
I updated the graphics drivers, disabled the plugins but the problem continues
.NET 8.0.14
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 11-28-2025 (M-D-Y).
    Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-30-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.74
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 12-30-2025
Driver Version: 32.0.15.9174
This sounds like graphics pipeline issues. If you start Rhino in Safe Mode (via Windows Start) are things still slow?
There are a number ways the hybrid settings can be altered (typically gaming ‘helpers’)
Thank you for the advice.
I have the geforce rtx 3070 as the rhino 8 gpu preference. Only when i updated to sr27 the problem started.
The problem presists.
Hi Sid -
I sent you links to SR26 a few posts ago. Can you confirm that reverting to that service release fixes the issue for you?
No. Reverting doesn´t fixes the issue. Then i discovered i had a big mesh object to the project. Sorry, and thanks for your help.
