Rhino 7 on Big Sur - Bug - Export Dialog options not showing
When I add a layout page to any model the options in the export dialog box are missing (they are visible only during resizing the dialog box).
Empty model with layout
Empty model no layout
For some reason I still have a problem with bug RH-61334 All Layouts Broken in Rhino 7 for Mac (https://mcneel.myjetbrains.com/youtrack/issue/RH-61334) which means there’s not a way for me to export multiple layouts at the moment.
Thanks for the report of the missing file format list and options when running Export from a layout page. I have filed this as https://mcneel.myjetbrains.com/youtrack/issue/RH-61670
I’ve also asked my colleague @mary to take a look at the other RH-61334 issue as she was actively testing that one.
Hi Richard,
The Printing of multiple layouts issue RH-61334 was fixed in 7.1. So you will need 7.1 or later.
ExportALL to PDF from a Layout is having issues including most Layout Annotations on the Mac 6 & 7 versions. This covered in RH-61685 ExportALL PDF format Excludes Most Layout Annotations, which has customer files so it is not open for public viewing, sorry.
You can download it from here and test.
So we know what you are running, please type SystemInfo in Rhino and copy it into your reply.
BTW I am running Catalina, not Big Sur and I am not seeing the RH-61670 issue that my colleague @BrianJ logged.
Sincerely,
Mary Ann Fugier
McNeel Technical Support and Training
Seattle, WA
Thanks, installing version 7.1 solves the PDF printing problem on Big Sur as well
System Info output (from v7.0)
Rhino 7 SR0 2020-11-9 (Rhino 7, 7.0.20314.03002, Git hash:master @ 9d1a3d02b292e00d3480c301d33f414d91acdcbd)
License type: Evaluation, build 2020-11-09
License details: Stand-Alone
Expires on: 2021-02-14
Apple Intel 64-bit macOS Version 10.16 (Build 20B29) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro13,3
Language: en-GB (MacOS default)
AMD Radeon Pro 460 OpenGL Engine (OpenGL ver:4.1 ATI-4.0.47)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: AMD Radeon Pro 460
Displays: Color LCD (258dpi 2x)
Graphics processors
Intel HD Graphics 530 (1536 MB)
AMD Radeon Pro 460 (4 GB)
Color LCD (1680 x 1050)
USB devices
Logitech: USB-PS/2 Optical Mouse
Mitsumi Electric: Apple Extended USB Keyboard
Apple Inc.: Apple T1 Controller
Bluetooth devices
None
Third party kernel extensions
com.Logitech.ControlCenter.HIDDriver (3.9.11) 4B5613F0-AE33-33F2-B39E-A571325BF920
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20314.3002
It seems 7.1 has an issue where I need to manually update the view (RedoView) when working in the layout view (including within details viewports), e.g. zoom/pan and no visual update of the layout space during drafting; it’s fine in 7.0.
It’s been awhile. Are you still experiencing this problem in the latest update to Rhino for Mac (7.3)?
I’ve not experienced the problem since installing the 7.2 update, seems fine on 7.3 too :+1:
