Layout views are empty? Rhino 7 for Mac
Hey there. I’ve seen people discussing this issue but haven’t seen it solved for Rhino 7 yet, for Mac.
I am trying to save a layout as a pdf with views of a model, but when I save as pdf or print, all of the views are blank and only dimension lines are visible. Any ideas why this is happening or what I can do to solve it? @John_Brock I have seen you assist others with this issue but not sure if you’ve found a solution?
many many many thanks
Hi Alexander -
On macOS, when in a layout, use the ExportAll command. Make sure the layers (both in the regular Layers panel as in the Layout and detail layer information panel) are not set to No Print.
If that doesn’t get you going, please provide a simple 3dm file that doesn’t print and post the result of the Rhino SystemInfo command.
amazing! this works. It’s odd that I can’t print directly from R7 but this work around will do. Thanks again!
