OXII
(OXII)
August 12, 2020, 3:24pm
1
Hi there,
I wanted just quickly tell you guys two bugs I found in Rhino 7 mac wip:
a) When I export a layout as pdf I can change the line and hatch pattern to “match viewport display”. But it does not have an effect, linetypes and hatches remain in pattern definition
b) When I open an AutoCAD drawing it opens model space and layouts but not the correct paper size. Paper size remains A4
To a)
Is it possible, that I preset “match vieport display” already in the detail view? So I can see it already correctly in the layout like I want the drawing to be exported.
pascal
(Pascal Golay)
August 12, 2020, 3:50pm
2
Hello - thanks, I see this (a). You should be able to see the print view in the details by enabling PrintDisplay
Actually, testing a bit more, in a layout detail, the Print dialog’s setting for linetype display seems to work, in a modeling viewport it does not, in the latest here.
If you have a simple Autocad drawing that shows the problem in (b), please post that.
OXII
(OXII)
August 12, 2020, 4:07pm
3
Print Display changes the line width but not the pattern scale. When I set on Print Display in Layouts it shows me different line widths (correct), but the hatch and line pattern remains in pattern definition scale.
When I export it as a pdf (Layout) it does it always in pattern definition scale, not in Viewport Display Scale, even if I switch the setting.
pascal
(Pascal Golay)
August 12, 2020, 4:17pm
4
Hello - I see…- can you run SystemInfo
in Rhino and post the results? - as far as I can see, here, from layouts this all works correctly both in PrintDisplay
and pdf output.
OXII
(OXII)
August 12, 2020, 4:25pm
5
Rhino 7 SR0 2020-8-11 (Public Build, 7.0.20224.12006, Git hash:master @ 218b9468b8ce41dbb6d0ccf27ee6decaeb17c70b)
License type: Commercial, build 2020-08-11
License details: Cloud Zoo
Expires on: 2020-09-25
Apple Intel 64-bit macOS Version 10.15.6 (Build 19G73) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro13,3
Language: en-IT (MacOS default)
AMD Radeon Pro 450 OpenGL Engine (OpenGL ver:4.1 ATI-3.10.15)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 2 GB
Graphics: AMD Radeon Pro 450
Displays: Color LCD (258dpi 2x)
Graphics processors
Intel HD Graphics 530 (1536 MB)
AMD Radeon Pro 450 (2 GB)
Color LCD (1680 x 1050)
USB devices
Apple Inc.: Apple T1 Controller
Bluetooth devices
Broadcom: Magic Mouse 2
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Users/achimreifer/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/maxwell_rhino.rhp/libmwdotnet_native.dylib
/Applications/Maxwell Render 5/libmxcommon.dylib
/Applications/Maxwell Render 5/libcudart.10.1.dylib
/Applications/Maxwell Render 5/extensions/wireframetexture.osx.mxx
/Applications/Maxwell Render 5/extensions/LensExtensions.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellCloner.osx.mxx
/Applications/Maxwell Render 5/libboost_date_time.dylib
/Applications/Maxwell Render 5/libboost_system.dylib
/Applications/Maxwell Render 5/libboost_filesystem.dylib
/Applications/Maxwell Render 5/libboost_iostreams.dylib
/Applications/Maxwell Render 5/libboost_thread.dylib
/Applications/Maxwell Render 5/extensions/xritebrdf.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellProcedurals.osx.mxx
/Applications/Maxwell Render 5/extensions/TiledTexture.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellHair.osx.mxx
/Applications/Maxwell Render 5/extensions/MGrassH.osx.mxx
/Applications/Maxwell Render 5/extensions/MGrassP.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellGrass.osx.mxx
/Applications/Maxwell Render 5/extensions/SubdivisionModifier.osx.mxx
/Applications/Maxwell Render 5/libmwglew.dylib
/Applications/Maxwell Render 5/libmwtbb.dylib
/Applications/Maxwell Render 5/extensions/MaxwellSea.osx.mxx
/Applications/Maxwell Render 5/extensions/Substance.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellScatter.osx.mxx
/Applications/Maxwell Render 5/extensions/AssetReference.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellVolumetric.osx.mxx
/Applications/Maxwell Render 5/libmwtbbmalloc.dylib
/Applications/Maxwell Render 5/extensions/MWObjectAlembic.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellMesher.osx.mxx
/Applications/Maxwell Render 5/extensions/MaterialModifiers.osx.mxx
/Applications/Maxwell Render 5/extensions/TableBrdf.osx.mxx
/Applications/Maxwell Render 5/extensions/rfmeshes.osx.mxx
/Applications/Maxwell Render 5/extensions/MaxwellParticles.osx.mxx
/Applications/Maxwell Render 5/extensions/rwmeshes.osx.mxx
/Users/achimreifer/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/maxwell_rhino.rhp/libmxdotnet_native.dylib
/Users/achimreifer/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/maxwell_rhino.rhp “Maxwell for Rhino” 5.1.6.1
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20224.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20224.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.0.20224.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20224.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20224.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20224.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshUtilities.rhp “MeshUtilities” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20224.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20224.12006
OXII
(OXII)
August 13, 2020, 10:33am
6
Also on this machine when opening a dwg it is much slower in 7 wip then in 5.
OXII
(OXII)
September 17, 2020, 2:49pm
7
Sorry guys for my stupid question, but where is actually the right place for posting Rhino mac 7 wip bug reports?
I noticed in Rhino 7 wip, that when I rotate or mirror a text it does not stick. This means that I want to mirror the text, but the orientation stays the same (mirror command or simply by Gumball). Is this supposed to be like that?
theoutside
(Kyle Houchens)
September 17, 2020, 6:13pm
8
you are in the right place, but its helpful for tracking purposes that you start a new topic for each bug you find,
nathanletwory
(Nathan 'jesterKing' Letwory)
September 17, 2020, 6:17pm
9
Do you have Horizontal to view
checked for your text? Uncheck that.
OXII
(OXII)
September 17, 2020, 8:12pm
10
No, horizontal to view is off. When I rotate the text with the gumball or mirror it, it remains still in the same orientation. Very strange
