Hi, everyone, when I use the command Filletedge edit I found I can only edit the last filletedge, which means if I use this command to some surface twice or more, I can’t edit the first filletedge. I want to know if any way I can edit because in many times I can’t make sure how many times fillet I need.
Yes, the edit feature is indeed of limited use.
Thanks!Hope this feature can be freer in the future.
You can edit the first set by first removing the second set as stated in the Edit section here:
Rhinoceros Help - FilletEdge | Rhino 3-D modeling (mcneel.com)
Then, if possible, add the removed fillets to the first set so that all the fillets are more accessible for editing.
Thanks!I will try it!
Hi Steve,I want to know how I can remove the fillets, because when I set the radius 0 it doesn’t work.
- _FilletEdge and pick _Edit option.
- Select polysurface and press Enter.
- Pick _SelectEdge option.
- Hold Ctrl and pick or window-select all edges and press Enter.
The FilletEdge command then ends with the polysurface edited and its previous set of fillets accessible for editing by repeating steps 1 and 2.
Thank you! Got it!
