Delete Fillet Command
I really enjoy the improvements on the fillet edge tool, and the ‘preview’ option within the command. I was wondering if it would be possible to add a “delete fillet” command (the way there is “delete hole” command), and it would make the edge revert to how it was before it was filleted. I understand that this would be in a future release, but it is something I have encountered a need for on numerous occasions. Thank you!
Hi Julia - you can get partway there in V6 WIP with the Edit function in FilletEdge - it is not as flexible as it should be in that the fillets must be from Rhino’s FilletEdge command to begin with, but the Edit function will allow you to deselect edges that were filleted previously.
