Rhino 7 default display options have been overridden. Unable to change
Hi all,
I am currently having an issue with my rhino 7 display options. I recently opened a rhino file that had its own custom settings for the shaded and rendered display options. Since opening this file, all my other rhino 7 files have changed to this display setting too. Anytime I make changes and try to restore defaults, the display just takes me back to the initial problem. It seems to have overridden rhino’s true default display options.
Here is a screenshot I took comparing rhino 7 (left) and rhino 8 (right) different shaded views.
The rendered display looks completely different too.
Could you try to click the Restore Defaults button to reset the display setting?
Hi Jessesn,
Unfortunately that does nothing. If I make adjustments to the display settings and then click ‘restore defaults’ it just restores to the original problem shown in the screenshots above.
I’d like to know which version of Rhino 7 are you using now? Please run the command SystemInfo in the comand line of Rhino 7 and post all popup content here. Thanks.
Does the emap file actually exist?
It should be located in your C:\Program Files\Rhino 7\System folder.
rhino_shaded_mode_emap_background
Save it as “rhino_shaded_mode_emap_background.png” …
Are you able to use any other picture?
Also at the bottom of that menu, there is the lightning setting, here’s mine, never edited:
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Educational Lab License, build 2023-09-05
Windows 10 (10.0.20348 SR0.0) (Server) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP (Hosting Remote Desktop session)
Primary display: Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 2-27-2024 (M-D-Y).
> Remote Desktop display device with 8 connection(s)
- Windows Main Display using connection #0
Primary OpenGL: GDI Generic: Microsoft Corporation. OpenGL Ver: 1.1.0
> No graphics device is being used for OpenGL
Secondary graphics devices.
NVIDIA Tesla T4 (NVidia) Memory: 0MB, Driver date: 8-14-2023 (M-D-Y).
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
Microsoft Basic Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 8-14-2023
Driver Version: 31.0.15.3713
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: n/a
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRsceneImportForRhino.rhp “V-Ray for Rhino VRscene Importer”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\RhinoGrow (c1a527a9-c3de-4ebd-90a2-7ec7875d5b08)\0.4.2.3\rhinogrow0423\Rhino 6.0\RhinoGrow.rhp “RhinoGrow” 0.4.2.3
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
Please try to download the latest version of Rhino 7.37 and try it again. Thanks.
https://www.rhino3d.com/download/archive/rhino/7/latest/
Hi, yep all settings are the same and I have that emap file in my system folder.
Since I am using a university desktop to run rhino I will contact my university IT department to see if they can resolve it. Thank you for your assistance!
Hi Lachie -
Note that this is not supported.
