Rhino 7 can't open DWG file
I created some technical drawings in fusion 360 and exported them as dwg files. When I try to open them or import them in Rhino, all the layers are uploaded in the layer tab but the board in empty. If i press CTRL+A it says “no objects added to selection”. The same happens if i click on the layers uploaded and press “select object layer”. I can open the file in Illustrator so there is no issue with the file.
Is there a solution ?
Could be that the dwg’s are in too new a format for Rhino V7 to read correctly. Have you tried in V8?
I havent upgraded yet to V8, but maybe i should
You can try with the V8 evaluation version and see if it works better…
