DWG does not open anymore
I can not open dwg files in rhino anymore.
If i open a dwg, rhino shows no drawing anymore.
Yesterday there wase a popup that i didnt read and click away.
Can it be that is turned of a option?
I use rhino 7
i alreddy uninstald rhino, turned of en restarted the pc.
reinstald the letest version, but it stil dos not work.
kind reguards Bert Veurink
Hey Bert -
Yes, but you’d have to also click the “do not show again” box for that popup not to show again. You can use the ResetMessageBoxes command to make all message boxes appear again.
For what it’s worth, uninstalling and reinstalling doesn’t change the settings, so that is pretty much always of little use.
What happens when you start a new Rhino document, draw a rectangle, and export that to DWG. Does that import into Rhino? If it does, please post a DWG file that doesn’t open.
Hello Wim,
I did draw a rectangle, saved it as Test.3dm en as Test.dwg.
Test.3dm opens, Test.dwg dos not open.
Met Vriendelijke groet,
Bert Veurink
VETEK – Technisch Tekenburo
Tel. : 06 83715401
info@vetek-tt.nl
www.vetek-tt.nl
Lijsterbeslaan 5
7771 DM HARDENBERG
(attachments)
Test.3dm (22.4 KB)
Test.dwg (27.1 KB)
S1.dwg (153 KB)
Dag Bert -
Can you copy the output on the command line from where you open the DWG file and paste that here?
Also, did you restore the message boxes? Can you post a screen grab of the import/open options for DWG?
Finally, please run the Rhino SystemInfo command and copy-paste that output here.
Bert Veurink
Hello Wim,
Can you help me with the information that i gave you in this mail?
Bert Veurink
Tel. : 06 83715401
info@vetek-tt.nl
www.vetek-tt.nl
Lijsterbeslaan 5
7771 DM HARDENBERG
